With very few exceptions, modernprinters need a full set of cartridges to even try and print.
the reasons for this are not quite an sinister as you may think. Many printers use a little colour and them finally apply black to create a very deep shade of black. printers also periodically do small cleans, checks and calibrations to keep the printer running as efficiently as possible. In order for many of these to be performed they need a cartridge of each colour to avoid damage etc.
SOURCE: Replacement toner cartridge chip not registering--1000.1 supply error
Use the override supplies out feature on the printer. If the error still stops the printer from working put in the old hp chip and again use the override out setting. GO TO >system setup>print quality>replace supplies>override out,
SOURCE: printer toner refilling
you can fill it by yourself.
1. buy good qulity magnatic toner powder.
2. basic for oppening 12a toner is 2 SIDE SMALL PIN, YOU CAN EITHER PUT THESE PINS INSIDE THE TONER WITH THE HELP OF HAMMER AND NAIL.OR OTHER TRICK IS TO FIRST OPEN THE GEAR SIDE TWO screw BY PHILIPS SCREW DRIVER and pick up drum then with the help of l type sharp longe nail try to pull pins from inside to out side this by process you see you get two part of toner cartridge one is wast chamber another is main chamber smaller one is wast cleane it .
open the both side of main chamber by unscrewing 4 screw ond pour the toner power powder in that main hopper and do all the steps in vice versa. your toner is filled TAKE A TEST PAGE.
I can frovide you photos step by step mail me [email protected] if neded
SOURCE: error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
SOURCE: Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
SOURCE: samsung ml-2240 printer is not accepting refill toners please hel
my samsung printer is model ml-2240 is not accepting refill toners please help, it is showing message that toner is exuasted, even though i refilled it, plesae help?
