You'll really will need the spanner wrench for the spanner nut on the basket drive block. If you try to make a tool or use some other method, you risk injury and possibly damaging your washer basket.
The spanner wrench is made by Supco, part #TB123A. It has various other part numbers from the appliance manufacturers. It is compatible with Whirlpool, Maytag, GE, and Kenmore. Most Kenmores are made by Whirlpool.
If you want the wrench same day, call local appliance shops and ask if they sell the spanner for the Kenmore Series 90. I got mine from a local shop and paid $13.
You could also buy one on eBay or another reasonable online source.
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=tb123a&_sacat=0&_from=R40
Or Google search: TB123A
Don't pay more than $20 including shipping.
You can always sell it on eBay once you are done with it. It won't lose much value being used since it doesn't really wear out.
You'll need a hammer too, preferably with a hard rubber head, or use a wooden mallet. If you use a steel hammer, be careful when you strike the spanner wrench to loosen the spanner nut. Wrap the steel hammer head in an old washcloth or rag. You don't want to accidentally strike the porcelain enamel lining of the basket - it will chip and that can lead to rust of the metal.
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
SOURCE: Kenmore 90 series washer w broken belt
Hello I'm afraid you didnt find a belt but maybe a piece of the coupling. Here are detailed instructions on replacing a coupling: from the limited information this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like: To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
