The kids tried to out smart mom. They thought they would continue to try different codes until they got it right with just luck. Now however they locked it up and the ipad will no longer let me even enter the code. Help--I know the code but the ipad says I have to connect with itunes. Itunes will not open up because the ipad is locked--Can anyone help? I just need to put in the code--I would like to not to reset everything
I don't have an iPad, but I did find this article. Sounds pretty much like what you're describing. Maybe this will help. It does say that making you connect to iTunes is for your protection in the event that someone steals your ipad.
Keep in mind, I have no idea how data is synced on an iPad, so I don't know if you may lose saved data on the device. Hopefully you've got that already synced/backed up:
http://ipad.about.com/od/iPad_Troubleshooting/a/How-To-Fix-My-iPad-Is-Disabled.htm
SOURCE: How do you reset an Ipad? It's stuck on Itunes and
Step 1
To reset the Apple iPad you should first locate the power
button. This is the button on the top right corner of the iPad when you
are holding it like a book, with the narrower sides on the top and
bottom.
Step 2
Once you have located this button you will need to simply
hold this button down for about 3 seconds or until you see the red
slider icon (a red rectangle with a white arrow facing toward the right)
come across the top of the screen. The slide area or the area to the
right of the button will be labeled Slide to Power Off.
Step 3
If you want to just reboot to iPad you can do that by
touching the red slider button and sliding your finger along the slider
area toward the right side of your iPad. The iPad will automatically
start shutting down, it may take it several seconds depending on the
amount of space you are using on your iPad and the programs you had
running when you requested the reboot.
Step 4
To turn the iPad back on or restart it after you have shut
it down just press the power button (remember that's the button on the
top right of the iPad).
SOURCE: The PC on which I had itunes that synced with my
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
SOURCE: iPad USB problems
http://www.iskysoft.com/apple-ipad/connect-ipad-to-itunes.html
this is so workfu!!!
tablette pc
lecteur ebook
SOURCE: Windows iTunes sometimes won't recognize my iPad when connected via USB
http://www.ehow.com/how_4661194_program-hyundai-keyless-remote.html
this may help you!
netbook 10 pouces
tablette pc
