Question about LG WM0642H Front Load
I have a LG WT5001CW top load washer. Recently the agitator plate began to loosen and fall off during spin cycle. Now when spin cycle starts and the tub turns it squeaks and grinds then I get a UE alarm.
  • LG Master
  • 1,556 Answers
The agitator has a gear like attachment that meets the long shaft up the center of the tub. If the alignment is off and not exactly in place the agitator will move or the gear-like part will wear down, become rounded, or break. The agitator must fit perfectly and tight. A nut on top (under the cap) has to be turned down tight.
Posted on Feb 27, 2014
  • 1 more comment
  • Jason Broussard
    Jason Broussard Feb 27, 2014
    Well the problem I'm having now is it will not finish a spin cycle. It will begin grinding and squeaking and shut down. I even took the plate out and tried it again but had the same results. I was thinking bearings may have went bad but I kind of wanted to be sure before I tore it apart.
  • Dayton Computer
    Dayton Computer Feb 27, 2014
    They use permanent lubricated bearings, not with ball bearings and they rarely go bad. You may get the unit apart, but in the long run end up with a pile of junk. If its worth it, have it serviced by an authorized technician.
  • Jason Broussard
    Any idea what else it could be? Maybe the coupler? I wouldn't think the clutch would be going out if it operates fine until it begins spin cycle.
6ya staff
SOURCE:
steelskyway
  • 22 Answers
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
Posted on Jul 31, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Posted on Aug 08, 2009
Anonymous
  • 95 Answers
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
Posted on Nov 18, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 20, 2010
DAVID
  • 472 Answers
SOURCE: My lg Tromm front load
these units have had alot of problems especially if it is on a pedistal ...they won't admit this is a problem but i have been a lg servicer for over 4 years now and see it everyday ...the unit has a stator on the rear of the tub and on the stator is a device called a hall sensor that goes bad very often... it is what controls the spped and balance of the tub..if the load starts getting unbalanced the hall sensor will tell the motor controller to slow the speed down... most likely this is your problem.... good luck please vote
Posted on Jan 03, 2011
I have a LG top load washer, model WT5001CW that makes a grinding sound during agitation cycle but not during spin. Drains like it's supposed to. Any ideas?
This sounds like you have a problem with the tub suspension rods (4 of them) if one is faulty, you will have to replace all four of them to cure the problem.
It could be that they just need to be realigned as the grinding sound is the inner tub contacting the outer tub housing.
Apr 18, 2016 | LG Washing Machines
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
Limited agitation during wash cycle Load Sense OK
Possible that the program selected is an easy wash as this is meant for daily wash , less soiled clothes.
If however the same situation is present in all the cycles then the capacitor to the motor must be checked as it can reduce the speed of the motor.
Also check the belt , check for friction on the drum spindle and the motor.
Jul 22, 2011 | LG WT5001CW Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Washing machine will not agitate but it spins.
The brakes are shot,so the tub spins in agitate will also cause it to leak part number R0000014 run about $25.
Look straight up from the bottom pulley you will see the brake assy looks kinda like a clutch plate,look around the outer edge of that you'll see the Pads they have two 3/8 inch bolts in each one,to get the new ones in you'll have to use a screw driver to open the plate.
Sep 23, 2009 | Amana ALW480DA Top Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
LG WM0642H Front Load Logo
841 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
