1997 Toyota Prado 5VZ-FE
Cylinder head bolts:
Tighten the cylinder head bolts in criss cross manner inside out, in four stages as under:
Stage 1. Torque the bolts up to 17 Nm.
Stage 2. 34 Nm.
Stage 3. Rotate all the bolts 90 degrees.
Stage 4. Finally rotate all the bolts further 90 degrees.
Main Bearings:
Tighten the main bearing bolts in two stages, as under:
Stage 1. 61 Nm.
Stage 2. Rotate the bolts further 90 degrees.
Big end bearings:
Tighten the big end bolt of connecting rods in two stages as under:
Stage 1. 25 Nm.
SOURCE: What is the torque settings for : cylinder head
Use a factory service/repair manual. You cannot rely on a possibly wrong answer from this forum.
SOURCE: 1997 Toyota land cruiser prado Rz compass bearing, temperature setting, etc.
I've been resetting pajero's compasses but try to get to an area where you can do 360 degrees turns (empty car parks, ) press the reset button and make 2 complete 360 turns slowly and normally this should set the compass bearing.
Let us know how you get on. Cheers.
SOURCE: cylinder head torque settings for a toyota 1493cc
If you have a vehicle application for the motor you can get a Haynes or Chilton manual from your local auto parts store. They usual run around $30.
SOURCE: whats the torque setting for big end bearing bolt
hi big end bearings are two stage, 25nm leave ten mins, then 49nm cylinder head bolts three stages 20nm leave ten mins, 40nm leave ten mins then 60nm check after 5,000miles hope this helps
SOURCE: Hi, I`m looking for the
Cylinder head instructions for Audi A4 1.8 (1997)
Tightening sequence:
Renew cylinder head bolts: Yes
Stage 1 - Tighten: 40 Nm
Stage 2 - Tighten: 60 Nm
Stage 3 - Tighten: 90 degrees
Stage 4 - Tighten: 90 degrees
