Replaced car battery end and now remote does not work
SOURCE: remote keyless entry not working
KEY FOBS FOR THIS MODEL MUST BE PROGRAMED USING A TECH 2 SCAN TOOL SO IT MUST BE DONE AT THE DEALERSHIP FOR ABOUT HALF HOUR LABOR HOPE THIS HELPS
SOURCE: Remote key fob suddenly stopped work
Check out page 57 of the manual:
http://www.motorcraftservice.com/pubs/content/~WO6FOC/~MUS~LEN/41/06focog4e.pdf
If that doesn't work, it sounds like a trip to the dealer.
SOURCE: car wont start
Sounds like you have a shorted wire causing a drain. I recommend disconnecting the alarm all together which should stop the short so battery can remain fully charged.
SOURCE: Ford F150 remote key does not work after car battery
Should not have happened,
For the Factory RKE ( Remote Keyless Entry ) have you tried reprogramming the key fobs to your truck. The procedure is in the owners manual ( need all of them at programming time ).
This is stored in NVR, and should not need to be done, but worth a try.
If this is an aftermarket Remote start / alarm, check the owners manual for t on battery replacement. Have seen some off brand with strange battery ( truck's battery that is ) replacement steps.
SOURCE: Keyless Remote Won't Work - But Car Starts
The remote receiver unit is located in the rear view mirror. This may be faulty. Since the car is new (less than a year?) you still may have the factory warranty.
Testimonial: "Thanks for the help. "
