Kenmore 24902 Top Load Washer Logo
Anonymous Posted on Jun 11, 2009
I have a series 80 top loader. It filled and
I have a series 80 top loader. It filled and washed. will not drain. I moved timer and will not drain or spin just agitate. Don't think timer is moving.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
527
Points
Screws holding the lid switch was broken. Had to replace lid switch.
Top loader. In wash cycle, why doesn't it fill or agitate?
There could be a defective cycle timer or a defect in some controlled assembly.
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
1helpful
1helpful
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
1helpful
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
1helpful
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
2helpful
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
1helpful
2answers
Washer wont progress through the cycles, suspect timer.
I was able to fix the problem by replacing the timer ($106 CDN). Thanks for everything.
Alexander
vince
