Need to know what year you have. If the starter solenoid is not activating the starter drive or jack shaft then the starter would spin freely and whine. If you have a bent shaft or otherwise that will stop gear engagement when you try to start it would just spin and whine. SO, if you get a whine the starter is spinning but not engaging.
If the starter relay makes a click everything up to there is working.
If the solenoid makes a click everything up to there is working ie the low current circuit is working. If the starter spins the high current circuit is also working and that leaves the above that the starter drive is not working to engage the starter with the clutch ring gear.
A common problem with snowblower starters. Rust gets all around the kick out pinion gear. When you apply power the throw out gear spring or mechanism is rusted an will not operate. Take it off engine an check for broken teeth as well. Most often is rust on starter clean if you can an lube but usually there is no fix
The starter on your bike uses a solenoid that also manually engages the starter gear. Try lubricating the solenoid mechanism and verify that the mechanism does not bind or stick. Once you have the mechanism freed up, check the starter again. If it does not engage, replace the solenoid (or, while you're at it, just replace the entire starter assembly).
