The front baffle/boot will likely need replaced. You can do this yourself but it takes some patience. You can order the part, list model #, at 888-321-3107. The procedure is as follows:'
1. Tilt washer, back against wall.
2. Remove wire spring with needle nose plyers. The spring is located at outside perimeter, under lip, of baffle.
3. Peel baffle from front panel.
4. Remove clamp from the outer tub lip. Look closely and you should find a large hose clamp. Use small socket wrench to loosen.
5. Install in reverse order. Be careful and take your time.
Rich
Western
Appliance Repair
Washer Repair
