sounds like you have a bad turn signal switch.
If the third brake light is working than we know the fuse is good and the switch is good. The third brake light bypasses the turn signal switch. If the rear turn signals are working than we also know that the wiring from the switch to the rear bulbs is also good. The brake lights and the turn signals are on the same bulb so the turn signal switch is what determines if the bulb gets power from the brake light switch or from the turn signal flasher. If the switch is bad usually the first thing that stops working is the brake lights.
Typically you can wiggle, jiggle, pull, push on the switch lever with you foot on the brake and get the brake lights to work. Sometimes turning the four way on and off several times will also get the brake lights to work. If this is the case than a new turn signal switch will solve you problem.
If you have any questions let me know!
I’m happy to assist further over the phone at
https://www.6ya.com/expert/jeremy_d728a59f986299fa
