IP Address unavailable/ cannot hook up to internet
Has it been rooted?
The equivelent of a an ipad/iphone jailbreak?
You can check this by doing one of two things.
The first is by going into settings, scrolling down to the bottom and clicking on About Tablet.
If not that then go to Settings/Device and then click About Tablet.
The second, and easiest, is to check to see if you have an app called SuperUser (SU).
If you do then your device is rooted.
Other ways to check, which is more dificult because of you not being able to get WiFi access, is by downloading an app called Root Checker or a Terminal app.
Root checker is self explanitory as it does exactly what it says on the tin.
It will check to see if you have root access to your device and will tell you either way.
The terminal app will show a hash tag symbol (#) as soon as it is started.
This is also an indicator of root access.
Have a look in the WiFi/network settings for your device and see if it has been set up to use a proxy or VPN.
If it has then clear these settings and try to enable the WiFi again.
If this doesn't work then i would restore the device back to factory settings as it could be a software issue.
Failing that you could always upgrade the firmware to the new 4.4 KitKat which, if your device is rooted, will wipe root access out.
