Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens Logo
Posted on Jun 11, 2009
Can't autofocus Nikon 50mm f1.8 lens
Everything says this is an autofocus lens! I have a brand new Nikon D5000 and was really looking forward to using this lens.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
7544
Points
35
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
2answers
How do I get my Nikon d5000 to recognize the lens with extention tubes?
Without any electronics the camera cannot recognize the lens. Set the exposure mode to "M" (Manual). You'll have to set both the aperture and shutter speed yourself.
You'll also get no exposure assistance from the camera's light meter. You can review the picture after taking one and/or use the histogram to tune the exposure.
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
2helpful
2answers
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
5helpful
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
2helpful
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
4helpful
I have a Nikon N80. I want to get a D5000. I have two Quantaray lenses for the N80. One is a 28-80mm af the other is a 70-300 af.I would like to know if the lenses will work. I know I will have no auto...
Yes, they will work. As you pointed out, they will not autofocus, but everything else will work, most importantly the exposure metering.
Bear in mind that the D5000 sensor is smaller than a frame of 35mm film. The lenses will seem longer on the D5000, about the equivalent of 42-120mm and 105-450mm. This means that the shorter lens won't really be a wide-angle anymore, though the longer lens will now be a whopping telephoto.
We have a nikon 50mm 1.4 nikkor lens that when
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
4helpful
2answers
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
1helpful
WILL THIS MODEL JELL WELL WITH THE NIKON 50mm LENSES (NORMAL) & OTHER BRANDS OF 50mm LENSES (NORMAL) THAT IS WITH NIKON D90 DSLR
The Nikon D90 works well with the Nikon AF 50mm lenses and most other brand Nikon fit AF lenses. If they are not AF you will lose autofocus and metering.
Do you know that on the D90 the lens becomes a 75mm but the aperture stays the same, so for instance the 50mm f/1.8 is a 75mm f/1.8.
Lens works fine in manual focus on Nikon D5000 but won't autofocus.
The D5000 needs an AF-S lens to autofocus.
Nikon have not fitted the mechanical focus drive to the D5000.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
