SOURCE: i need the diagram schematics on a MITSUBISHI WD-65C9 television
check our site www,tvrepairkits.com - may have one
SOURCE: Mitsubishi TV model wd-65c9 turns itself off how
l would first look to front of set when this happens---set has indicator lights that will blink (each is explained in the owner manual)
Could be Lamp, Ballast, power supply etc.
SOURCE: mitsubishi model wd=65c9 when turned on green light blinks repeatably sound comes on but no picture
The bulb that lights your picture is burned out. Buy a new warranted bulb from shopjimmy.com $85 with the housing. You can replace this yourself in 5 minutes. Shop jimmy has a video showing replacement. Remove 2 screws that hold the housing in place, slide the bulb out and slide the new bulb with housing in and replace the 2 screws. Plug in and enjoy your tv.
