I bought the recommended filter for my Samsung refrigerator and it does not fit. I called Samsung and they didn't help at all.
SOURCE: I need to bypass a filter in RS267LASH Samsung refrigerator
From the Samsung Online FAQ for my RF266AASH
Can I Use the Water Dispenser Without a Water Filter?
The water and ice dispensers will work without an AquaPure water filter installed.
The water filter housings are designed as rotary valves that allow the water
to bypass the water filter whenever there is no filter or the filter is not
in the lock position.
Models designed for use with the AquaPure water filter are shipped
with a cap in place to cover the opening and keep it free of debris prior to
the installation of the water filter. It is not necessary to have this
cap in place for the unit to bypass the water nor is it intended to plug the
housing to prevent leaks.
Note: This does not apply to the Quatro Convertible models. The filter
must be installed on this model.
SOURCE: Samsung Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
SOURCE: turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
The filter is part # DA29-00003G. Samsung recommends this for the refrigerator RFG298AARS, but it doesn't fit. I can't get anyone at Samsung to understand that!
