My CDs will not play I get a message that read TOC
SOURCE: HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
SOURCE: I have a harmon kardon cdr 30 cd recorder. After a
Hi
First thing to do is disconnect the unit from the mains supply for 15 mins to allow for a hardware reset,and then power it up and try again.
If it does not come up, then the power supply has been damaged by a power surge associated with the outage. You may have no choice but to take the unit to an authorised HK repairer. Let me know how you get on with resetting the unit. Please take the time to rate this solution. Happy to talk to you more about it. Cheers
regards
robotek
