Question about HP LaserJet P2015dn Printer
When i getting a dubble side command , first printer showing a device error, after then i had press the ok button , printer have accpect the command , but last print are not take due to reason by printer showing same error then press , command accpect, so how to resolve my problem.
Anonymous
SOURCE:
Anonymous
SOURCE: hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Posted on Jul 27, 2008
Anonymous
SOURCE: When I turn on my printer I get the message Error Press OK
You have to refit the micropump gear, this is happening because this gear should be out of its place. It's on the left side of your printer. I.ve just solved the same problem.
Posted on Nov 27, 2008
Anonymous
SOURCE: system error in printer hp deskjet 3320
Normal 0 In XP go to Control Panel
Open System
Click the Advanced tab
Click Settings under Performance
Click the Data Execution Prevention tab
Make sure Turn on DEP for all programs is NOT checked, check Turn on DEP for essential Windows programs.
Posted on Feb 10, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: HP photosmart3210 printer problem error message
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Anonymous
SOURCE: unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
Posted on Apr 04, 2010
We have a Hp laserjet p2050, when i get the print , printer showing a some device error, press ok, then printer accpect the command ,so how can resolve the issue.
does this happen in all jobs or just certain jobs.Try printing a config page by going to reports and config page, enter.
Mar 01, 2014 | HP LaserJet P2055d Printer
Tip
Xerox Phaser errors 09,005.49, 09,006.41, 09,007.42, 09,008.43
Hi.
This procedure will clean errors like Note: type errors 09,005.49, 09,006.41, 09,007.42, 09,008.43 ('Ink Loader Fault - respectively cyan, magenta, yellow, black)
Start disconnecting the power cord for ten minutes , then remove the black stick check it and put it back. Ensure you are using original cartridges.
Turn the printer on, to enter the Service menu:
1. -You can access the menu using the FRONT PANEL:
  • Press the down arrow, select "Troubleshooting" from menu and then press OK
  • Press the down arrow until you get "Maintenance Tools" and then press OK
  • While holding the arrow at the top, also press the down arrow at same time, to access the hidden service menu.
  • Scroll down the menu until getting "Enter Diagnostics" and click OK. Wait about 20 seconds, then go to Step 3
2 - If you can not Access the menu because the printer is stuck with the error message on display.
  • If the printer is on, turn it off and wait 10 seconds. Turn the printer back on.
  • Wait to see the Xerox logo on display.
  • Before Xerox logo getting steady on display, press and hold the Back button (back) and 'i' (Help) on the Control Panel.
  • Hold down both buttons until the display shows "Beginning Initialization Service Mode". Release the button and the printer will restart showing the menu "Service Diagnostics".
3 - Scroll using the arrows until "Function Menu" appears and press OK
4 - Scroll using the arrows until you get the command "Clear Fault ISC" and press OK twice to confirm.
5 - Now push the "back" button on the control panel (usually at the left), then press "Exit Diagnostic", then OK twice to confirm.
6 - The printer will restart, and the error message will be gone.
7 - Remove the sticks, check them and load them back correctly.
If the error does not clear, then it is due to a fault, in which case contact Xerox technical support at the number listed on the owners manual.
on Jan 30, 2010 | Xerox Phaser 8550DP Printer
When i print error 5800 will appear
This is an indication that the waste tank counter is full. This can be reset by using the following method.
First download this tool:http://www.ziddu.com/download/11944259/PCM_servicetool.rar.html
Step 1: enter in service mode in order to used the resetter:
  • Turn off the printer without pulling the power cords.
  • Hold down Resume button and press Power button.
  • Keep holding down Power button and let Resume button go.
  • Then Press Resume button 5 times then let both buttons go.
  • The Alternate Blinking error is gone: the printer is in Service Mode state.
Step 2:
  • Extract the resetter and double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • That's done.
I hope this helps, if so please rate this below.
Regards GM
Apr 21, 2011 | Canon iP2700 Inkjet Photo Printer
I have a IBM 9068 Model S01,it is sometimes showing error code 18.If I tilt up the printer assembly during the printer power on it is ok.If I tilt down the printer assembly meaning to it's original...
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Mar 28, 2011 | IBM Office Equipment & Supplies
Have a Xerox Phaser 8560 DN printer when trying to print test page or anything and get: ERROR: rangecheck OFFENDING COMMAND: setpagedevice STACK: -dictionary-
Sounds like a Postscript error. Try resetting the NVRAM. 'Troubleshooting', Service Tools', 'Reset NVRAM'. If that doesn't work, go into diagnostics and clear the PS NVRAM. 'Troubleshooting', 'Service Tools', press and hold 'Up Button' then press 'Down Button'. This takes you into a hidden service menu. From there scroll down to 'Enter Service Diagnostics' and press OK. Printer will turn off and reboot into diagnostics. Scroll down to 'Function' menu and press OK. Now scroll down to 'Clear PS NVRAM' and press OK. Press 'Back' button to return to first menu, scroll up to select 'Return To Customer Mode' and press OK. Don't forget you will lose all printer settings including your IP address. As you cannot print out a configuration page, this will be like setting the printer up from new as you will have no reference to your earlier settings.
Hope this helps.
Jan 06, 2011 | Xerox Phaser 8560DN Laser Printer
Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Brother MFC-425CN...ERROR MESSAGE READS...UNABLE TO CLEAN...TRIED EVERYTHING IN MANUAL????? WILL NOT SCAN OR PRINT...OR TEST PRINT ETC ETC...
You need to contact brother regarding that error message. It simply means that your printer's purge counter is full and you just need to RESET it to ZERO. I already have a post regarding this "unable to clean" error but it is for Brother DCP-150C. I also got it from a Brother Tech Support. So I think the commands in my previous post is different since you've got a different model. Better ask a Brother Tech Support for the procedure in resetting the purge counter.
Anyway, this is the post, if the sequence is right for your device, then this will work:
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET/OK
b. 0 then press SET/OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET/OK
b. 7 then press SET/OK
b. 3 then press SET/OK
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET/OK
b. 1 then press SET/OK (To reset unit)
a. 9 then press SET/OK
b. 9 then press SET/OK (To exit Maintenance mode)
Dec 27, 2009 | Brother MFC-425CN Multi-Function Center...
Printer is ok but when i give the print command after some time it shows error which ''print error'' what is the problem
I'd like to have answers for some questions.
1) What interface do you use? Parallel or Serial
2) Does the printer run the self test? Switch on by holding LF/FF
3) Let me know the printer settings. You can find it by Switching on printer by holding FONT button. After it prints some data, press LF/FF. You will get the current settings of the printer.
Thank you!
Sabharish
Oct 13, 2009 | Epson LX-300 Matrix Printer
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart C6280 All-in-One i have an Error massage (Ink System Failure)it says: ink system has failed. unable to print. refer to printer...
ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
Press and release the “OK” button.
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
Oct 02, 2008 | Office Equipment & Supplies
Dubble Sided Printing
control panrl >printer>right click >printing perferance> quality?copies>uncheck printing on both sides>apply >ok ,try know >
Mar 12, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP LaserJet P2015dn Printer Logo
Ekse
Thomas F. Schneider
