Sennheiser ew100 g2
Batteries get hot and drain quickly when the microphone is on. I'm thinking it is a short in the microphone. However the positive and negative leads aren't showing one with a meter.
  • 63 Answers
You won't need a complete short to drain the battery much faster. Unless you can compare the figures to a known working one it's difficult for you to tell what is right and what is wrong.
Is this a handheld or a beltpack? Is it a genuine unit or a Chinese copy?
A set of GOOD batteries (Duracell, etc) should last between 6 and 8 hours minimum with these units.
If you have the tools you could take the unit apart and look for signs of failed components. A partial short circuit on a board due to moisture (from sweat or other liquids) can cause higher battery usage.
At the worst case, Sennheiser fixed price repair is around 60pounds exc vat.
Posted on Mar 04, 2014
6ya staff
SOURCE:
Pokethebear
  • 11 Answers
SOURCE: on/off button broken
You should'nt need a scematic, this happens all the time with the ew100 handhelds. you will need to remove the three star bit screws between the screen and the batteries, pull off the end cover and with a small screwdriver or some long needle nose pliers- put the red button back into the hole from the inside of the cover. Just take care when putting the end cover back on- sometimes its a bit difficult.
Goodluck
PTB.
Posted on Apr 02, 2009
Anonymous
SOURCE: ew100 g2 - getting a lot of distortion and must
Add a DI box to clean up/boost the signal of that mic. If all the channels are doing this, get a bigger (more watts) amp so that you have more headroom.
Posted on Aug 26, 2009
Anonymous
  • 5 Answers
SOURCE: Sennheiser ew 100 g2 handheld microphone loose coil in capsule?
I had a similar problem with a sure sm 57 that I used on a guitar amp. I don't know if this is the correct fix but it worked for me. I took thin strips of paper to use as spacers and placed them evenly around the coil. I used a hot melt glue gun and placed 3 small drops around the edge of the coil. Remove the spacers and the coil should be secure.
Joey Clay
Posted on Oct 28, 2009
Rob Beech
  • 63 Answers
SOURCE: microphone of our ew100 failed due to stress at
Hi, Sennheiser SHOULD still service these. I'd recommend having another go.
However, i'd like to clarify which part of your system has failed. Is this the locking jack plug on the ME2 / ME4 tie clip mic. A common failure point.
Or the antenna on a beltpack (also common), or something else?
They're both fixable, the locking plugs are available to buy now from other suppliers. And the antenna are just an m3 plug with a solder bucket in the top. A HOT soldering iron, and a bit of heatshrink can repair these.
If you don't have any luck then you can contact me direct and i'd be happy to have a look for you. rob@cnics.co.uk
Posted on Dec 19, 2009
Vito Vacirca Jr.
  • 140 Answers
SOURCE: I have 3 sennheiser ew100 G2 handheld mics which
You can send them to Pro Line Music
490 Lincoln Highway
Fairless Hills PA. 19030
215-736-8055
It will cost $65. for evaluation + parts+ aditional time past 1hr. + return shipping.
Posted on Jan 16, 2010
Batteries Hot
This sound to me that an electrolytic capacitor has given up and went short circuit especially tantalums it can be a transistor or I.C. but I doubt it
Mar 01, 2014 | Sennheiser 100/500 G2 Series Wireless...
I have 3 sennheiser ew100 G2 handheld mics which don't work properly ( rattling sound ect;)i would like to send them off to you to get a quote on how much to repair them how do i go about this.
490 Lincoln Highway
215-736-8055
Jan 13, 2010 | Sennheiser Evolution G2 100 Series UHF...
Microphone of our ew100 failed due to stress at plug head. My attempt at repair has not worked. The very fine copper line, as well as the shielded core may have defeated my attempt. Sennheiser will no...
Nov 30, 2009 | Sennheiser (EW100ENGG2C) Professional...
Ew100 receiver is getting siganl but no sound is coming through
Maybe the gain in the receiver is down.
You can adjust the outputgain the menu.
Good luck,
Gerard
Nov 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Ew100 g2 - getting a lot of distortion and must scream into mic to register any voice sound. Volume and channels for mics are all adequate
Aug 25, 2009 | Sennheiser Audio Players & Recorders
On/off button broken
Goodluck
PTB.
Mar 31, 2009 | Sennheiser 100/500 G2 Series Wireless...
Im using rechargable batterries in my handheld ew100 mic but thes
Rechargables aren't recommended for wireless operation because they can die suddenly without warning. Plus the older they get the shorter their life span. Go back to good quality batteries and you should be fine.
Mar 27, 2009 | Sennheiser (EW100ENGG2C) Professional...
Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
140 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
