I suppose there is no hardware fault. Please reinstall touchpad drivers from the following website and try going into Mouse settings and check if scroll bar is enabled. Install the one apppropriate to your hardware for eg if your touchpad is ALPS install ALPS driver.
ALPS driver:
http://global-download.acer.com/GDFiles/Driver/TouchPad/TouchPad_ALPS_7.102.2002.208_W7x86W7x64_A.zip?acerid=633917164365142548&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205532&OS=712&LC=en&BC=ACER&SC=PA_6
Synaptic driver:
http://global-download.acer.com/GDFiles/Driver/TouchPad/TouchPad_Synaptics_13.2.2.0_W7x86W7x64_A.zip?acerid=633917205086579178&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205532&OS=712&LC=en&BC=ACER&SC=PA_6
Source:
Drivers and Manuals
Download free driver for notebook Acer Aspire 5532 Windows 7 XP Vista
SOURCE: Windows Vista Laptop Touch Pad Scroll not working
download touch pad driver from internet
giveme your laptop company and model number
SOURCE: Acer Aspire 5532
look there is a problem with the touchbad diver and this is common but the keyboard must work it s nothing with the keyboard so please check if all the key board works under another operating system and then if it wrks try to reinstall windows 7 again and it must work conntact me if you still have a keyboard problem you must try to plug a usp keyboard and see if it work so you have a problem with your board again if it worked you have a problem with your keyboard if it didn't work then try install windows 7 agin
SOURCE: Possible to install Windows XP on an Acer 5532?
Yes you could but Acer won't support it. You either have Vista or 7 in it. If Vista, update to 7 and be done with it.
If you want XP, first copy a full image of your present OS on a external drive using a program like Acronis True Image Home. Then reformat your hard drive when doing an XP install. Do you have a full version XP install disk?
SOURCE: I just bought an ACER ASPIRE 5532 SERIES LAPTOP
press the button to the left of the power button and it should work again.
SOURCE: coprocessor driver for windows 7
Try letting Windows update detect and install the coprocessor driver for you.
You may have to perform the Windows update a couple of times before the device is detected.
When you start windows update it will give you a list of software and drivers that are available, you will in the list that there are optional updates available. Check there to see if the coprocessor driver is there and install everything except for the language packs.
Hopefully this will resolve the problem for you.
Good luck.
