For whatever information value this may be,I am using a hdmi cable to connect the cable box to the tv.To explain futher,the Toslink cable from the Panasonic is connected to the Digital to analog converter imput and the transmitter red-white imputs are connected to the digital-to analog converter outputs as is the 5v. dc power supply
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
SOURCE: Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
SOURCE: My television does not have
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
Alternatively you can run both DVD audio and video through the cable box
Alternatively you can run the cable box through the DVD player
SOURCE: i am attempting to use my sennheiser rs 110
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left
Red = Right
In this case
Black = Left
Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
I hope this helps,
Magoo
