Remove the ink collector from the back. If full, install new one. If it's not full check the contact (it looks like a phone jack) itmust be clean. Look inside the machine to if if the mating connector is dirty.
The printer has a problem with the system program you should call service to fix that here is nothing you can do by your self
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
SOURCE: Richo Printer many white lines on black print out
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Ricoh 3050 printer, Error 990
We got the same error on our machine, so I called Ricoh Direct Tech Support and they said it is a known manufacturer's error. All you have to do is 1. make sure your product is registered, 2. call them up and tell them the error and 3. they will send you a new machine. You will have to send back the old machine in the same box, but they provide the RMA for you to ship it back in.
Good Luck!
SOURCE: have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
SOURCE: purchased new fusing unit for ricoh cl3500n;
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
