This is any help. May not be of any help. Here goes.
Red wire is Power
Yellow is radio memory
Black is ground
No mention of a black? Hmmmm
Double check the wire schematic, there might be a boo boo in that area. - Good Luckand get it fixed before your radio goes poof.
The amplifier is in the passenger side rear quarter panel.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Push and hold the phone button until you get a display, now using the big round button in the middle turn to your right until you get to the Bluetooth set up it will say program or delete and you delete the the paired device, and that takes it back to the factory reset.
You need to buy a wiring harness compatible with your vehicle. The wiring harness will connect to your vehicle OEM plug and the other end you need to splice it with the wire that came along with your car stereo.
Try taking it to an authorized Chevy dealership so they can unlock it for you. It does this because virtually EVERYTHING goes into the radio harness. And to give us installers and consumers a headache.
