Question about Kyocera Color Copier, Km-c2525e
Replaced black toner as the copier asked for and still say it.. I replaced toner motor for that color but it still says add k toner ... WHY ?
    New Friend:
  • 43 Answers
Has bad toner sensor in developer unit for black
they only sell this as an assembly. part# 302fz93113.
Posted on May 09, 2014
6ya staff
SOURCE:
What is the solution of sharp showing f2-40
toner problem, remove toner restart copier and reinstall toner. If that doesn't work you may need a new toner.
Jul 08, 2014 | Sharp AR-M237 Copier
Printing alignment soloution
I have seen this problem before a number of times - the usual culprit is the Black toner/drum cartridge I would first ask if you have recently changed this and if so would suggest you replace again with a new OEM unit from HP and NOT a 3rd Party ReManufactured unit. the problem lies with Very stiff toner units adding drag to the motor servos driving the toner unit,
if replacing the black toner has not cured the error then My next move would be to replace EACH consumable unit until the error is cleared
I have never Yet had to replace an internal component for this error, just a toner or Transfer belt has been the culprit. The fuser/Fixing unit is not likely to have an effect on this fault.
Jan 25, 2014 | HP LaserJet 4650 Color Printer
9-357 problem
Hi there! The Black Toner Dispenserof your machine is broken. Please check the following
1. The Toner Dispenser Motor located at the back of the Toner Cartridge Housing Assy (Behind Black Toner, larger Motor at the top)
2. Black Toner Dispensing Auger set located just below the Toner Cartridge.
3. The Dispensing Assembly behind the Developer Waste Container.
Regards
Apr 27, 2011 | Xerox DocuColor 12 Color Copier
Panasonic FPD450 the toner bottle doesn't rotate. Does the motor need to be replaced?
There are 2 reasons that the toner bottle would not rotate. First reason is that the machine does not think it needs toner and is not trying to add toner. Is your replace toner light on on the copier?
The other reason would be that the machie is asking for toner, the toner light is on, but the bottle still does not rotate. In this instance you may have a defective motor or possibly the connector going to the motor has come loose.
Good Luck and Thank You for using Fixya.
Sep 20, 2010 | Panasonic DP-C354 Copier
Keeps asking for black toner even after changing toner
Hello sir; on the black developer unit have senser call toner end senser that one defective have to replace it.
Apr 20, 2009 | Toshiba E-Studio 3511 Color Copier
Toner bottle does not turn to add toner
is the toner the Correct toner. If it is wrong the bottle will not Mesh with the motor
Apr 01, 2009 | Panasonic FP-7750 Black and White Copier
Hello, I have a Minolta Magicolor 2490 MF, printer/copier. The display shows "low toner". My question is this: Is it possible for the machine to identify the seperate toner levels, so I can replace only...
hi,
if it has a 4 toners which color are separated (the cyan, magenta, yellow and black) then you can replace a low toner one at a time. for example if the black color prompt you that it needs a replacement then you can put off the black toner without changing the other color not until such time it prompt you that it needs replacement. For replacing it I believe it has an instructional manual or if it's still under warranty you can ask assistance from your dealer to help you how.
Dec 20, 2008 | Office Equipment & Supplies
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Toner
Di200 [Subject] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good. [Description] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
Kyocera Color Copier, Km-c2525e Logo
69 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
