Tension pully seized belt broke over heated witch heater hose usually breakes first top or bottom
SOURCE: bmw 320i touring 1995 n reg
check and see if you get water/coolant circulates when you have the cap off (only check from cold start) the original water pump came with a plastic impeller and tends to strip on the shaft also check your thermostat before replacing water pump.
SOURCE: 1991 honda accord is overheating. Installed new
When the car is completely cool,check the electric fan(s) for smooth rotation.
Clean/check/change the thermo sensor,contact and wire.
Excavate air pocket in coolant system / check for head gasket leak
This test will kill two birds with one stone.
MAKE SURE THE COOLANT SYSTEM and ENGINE IS COLD!
RAN THIS TEST IN A WELL VENTILATED AREA ONLY!
You will spill some coolant during this air pocket purge test.......BE
KIND TO THE ENVIRONMENT and ANIMAL please clean up after the test!
Put the front end on a pair of ramp or park your car on a VERY STEEP HILL (radiator facing top of the hill) .
Top of the coolant reserve tank
Let it ran for 10-15 minutes.
Monitor for air pockets escaping from coolant reserve tank.
Small amount of bubbles is OK at 1-5 minute mark
After the thermostat open up (after 195 F warm up) at
5-12 minute mark or after high idle you should see less bubbles.
If you do not see any in rush of bubbles then your thermostat may be
partially stuck or rusted badly inside the thermostat hosing.
Give the thermostat host few gentle taps.
If you see larger bubbles surfacing after 15 minutes then should do a
hydrocarbon (HC) dye test to test for potential head gasket leak.
Let engine cold down and top off coolant reserve tank.
Start monitor for coolant lost
A coolant flush is require every 2 years or 24,000 miles.
I recommend the thermostat that has a relief pop-let to reduce the change of burst radiator and coolant hoses.
Make sure you get a new thermostat gasket,black RTV and fresh coolant for the job.
Please post more information by clicking the comment link on the top right corner.
DON'T FORGET to RATE ME if my tip is helpful to you!
SOURCE: 1995 Chrysler Cirrus overheating
Probably not water pump. Engine is notourious for vapour lock.
Cooling system must be blead of air before thermostat will work. Cool bottom rad hose is a dead give away. If you are still watching this forum reply , and I will walk you through the only way I know how to make it work properly. It's actually easy if you do it my way. I have worked on lots of cars , and this engine was the hardest to bleed out. Did one Yesterday , and works perfect.
Testimonial: "I need help on how to bleed the system thanks"
