I'm trying to place my tv stand back onto my tv after having it mounted on the wall for a year...However, I lost the screws and need to get replacements does anyone know the size of the screws that are used?
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
SOURCE: try to mount TV to the wall and need to release
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted
wall bracket appropriate for the size and weight of the
LCD TV:
32HL37/32HL37U/32HL17/32HL17U:
38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component
connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket.
Before proceeding, make sure the appropriate bracket(s) are
attached to the wall and the back of the TV as described in the
instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the
back of the TV, remove the pedestal stand from the TV as
described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
SOURCE: How does one remove the Toshiba TV stand.
ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
Testimonial: "Thanks for that - will try it!"
SOURCE: Can't find screw size to
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
SOURCE: I LOST THE SCREWS OF MY TABLE TOP STAND OF MY
Read the informations of those screws to tighten the tv and the base stand together.Read it in ur owner manual for those exactly screws sizes.Standard screws tvs sizes for a 46" are screw (M4 X L16).
