Televison & Video Logo
m
melle sol Posted on Mar 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Westinghouse auto scan
My 24" westinghouse is stuck in auto scan mode. I have no remote, am not connected to cable or satellite. I only use chromecast so I don't even need channels - I am able to use the buttons on the side of the TV but there is no way to press 'enter' - my tv goes through the entire auto scan but then it goes back to the floating window that says 'please run channel auto scan' - please help. i am about to lose my mind!
  • melle sol
    melle sol Mar 03, 2014
    I've already unplugged the TV (for hours) to reset - and when I turn the TV back on the floating window that says PLEASE RUN AUTO SCAN is still there!
  • therealamoy .j
    therealamoy .j Nov 27, 2020
    finally someone understands
Don A
Level 3:
  • Westinghouse Master 4,384 Answers
  • Posted on Nov 27, 2020
Don A
Westinghouse Master
Level 3:
Answers
4384
Questions
5
Helped
1319719
Points
25577
You can try attaching an antenna to the tv and waiting to see if the autoscan finally terminates as the TV in present condition is searching for channels it can not detect. But several things are compounding your difficulty. You do not appear to have model number, remote control, or user guide. Knowledge of the model number would help with identification of the controls on the TV and without that, you are unlikely to get much in the way of assistance. You or an assistant would track down the user guide which is sometimes at the manufacturer's site and other times further afield.
If attachment of an antenna did not stop the autoscan cycle, you would likely seek the procedure to return the TV to its "defalut" state. The manual may or may not help with that but it is a starting place. Acquisition of the model number accompanyed by the brand name and the word remote could get you to a site that sold either a universal remote or better yet the original. With the original remote and a user manual, you have better proscpects of working your way through menus. Is it safe to assume you have seen chromecast on this TV before all cabling and remotes vanished.
Some Westinghouse TVs only have a power button which is a good reason to supply a model number. If there are more buttons affecting input , you might be able to get the TV to the mode where it accepts Chromecast. But if attachment of the antenna does not after a time stop the autosearch scan and any attempt to restore the tv to "default" has failed, you may have a motherboard problem.
Your journey and further assistance from someone will begin with you acquiring the model number which in on the set somewhere. But there is nothing wrong with making a quick fix attempt by attaching a TV cable. If that stops the cycle and there are other control buttons affecting input, you might just stumble into a fix. If you post again, be sure to supply that model number and brand.
5 Related Answers
A
Anonymous
  • Posted on Jul 02, 2008
SOURCE: can not program my cable channels
move your antenna around to get maximum signals to be able to scan.
Chi Chu
  • 8457 Answers
  • Posted on Apr 15, 2011
SOURCE: panasonic viera TH50PZ700B 4yrs old. will turn on
Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Go into the tv menu go to PICTURE to go down to do a resetting to the tv Tuner signal board.Tries scanning for channels again.The tv should be work again,if it still have the same result.The tv main board,the tv Tuner signal board is bad.Can u do some mechanicals work like take things aparts and putting it back together again?Yes?Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Anonymous
  • 304 Answers
  • Posted on Jun 15, 2011
SOURCE: the local cable company has
Hi, You need a analog and digital tuner in the TV, which it sounds like you don't have, or a digital cable box.
Michael Green
  • 3799 Answers
  • Posted on Feb 04, 2012
SOURCE: h i have no remote for hannspree tv, tried scanning channels with buttons on the side of tv, dont know what i touched,but now its wont do anything just says scan channels. wont even turn off
Remove power for about 30 seconds and try again.
rickbrashear
Ricky brashear
  • 176 Answers
  • Posted on Aug 06, 2012
SOURCE: can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
2answers
How to do channel search
go to the Menu and you should find it.
Watching tv and all of a sudden it starts flipping through the channels and won't stop
If you have _no antenna_, make sure the menu (for channels) is set to either ''cable'' or ''satellite''. The TV needs to _know_ there are no ''antenna'' channels to scan for.
If the above doesn't work, try unplugging for a _full_ 24 hours. Then plug in, turn it on, go directly into ''menu'' and do like I stated above.
Note: ''Capacitors'' can ''hold memory'' for a long time. That is why ''unplug for full 24 hrs.''
I have a Westinghouse DWM32H1Y connected via coax to cable. Auto scan will not pickup digital channels. Can someone help?
Only suggestion I have is to make sure you are in the correct mode (ANTENNA if you are hooked-up to a regular aerial, and CABLE if you are hooked-up to cable).
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Tried hooking up my tv to the satellite cable but I have nothing but blue screen and it says no signal. tried to auto scan and it wiped out all my channels. How do I fix this problem?
I think I see what happened here. Normally you have the tv cable connected to one connector and satellite or others to different connectors. When you want to switch you use your remote or the tv controls to change the source.This will preserve the scanned channels as well. On your remote you should see source or something like that. As you select it it should shows options like antenna, cable aux1 aux2 and so on.
So hook your tv up and rescan your channels. Then hook up the satellite to one of the other inputs. Then use the remote to switch the source. You will never see more than one sateliitel channel at a time and you will have to use the satellite remote to change channels on the satellite box.
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
3helpful
2answers
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
1helpful
HOW CAN I RESET TO THE FACTORY DEFAULTS SO THAT I CAN MAIPULATE THE PICTURE MODE FROM THE REMOTE? PRESENTLY I CANNOT PERFORM ANY PICTURE MODE CHANGES AND THE TV APPEARS TO BE STUCK IN THE NORMAL SETTING,...
If you are connected to a cable box or satellite receiver and it is high definition (hdmi or component cables) you would manipulate the screen size with the hd zoom, aspect, or format button on the cable or satellite company's remote.
If the television remote control also has it you would further adjust the screen size with a view mode, aspect, or format button
4helpful
2answers
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
1helpful
Screen is cut off top/bottom
I had the same problem on my 47 inch Westinghoust HDTV. It turned out to be a problem related to my satellite tv (Direct TV) remote controller. Someone inadvertently hit the "format" key and jacked it up. I set back to it's original position and get the full screen. Don't know if you have cable or satellite, but this may help someone having this problem,
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
