I have a kenmore top loader washing machine and its trying to spin but its either really slow or not spinning at all. I have tilted it on the side and tried it and can see that the clutch on top of the gear box is slipping. the little one,not the one closest to the tub with the big yellow spring. I took it apart and it has a little blue spring,and small plastic "shoes" like on drum brakes. Could that possibly need replacing? What do you think? Thanks
Yes Friend, You need to just replace the clutch assymbly. It looks like you know the mechanics of your machine well. I've included the complete instructions below to help others that may have the same problem. It's easy to replace the clutch assymbly on your machine. First, pop the cover off the top of your agitator and remove the bolt that holds it in place. Gently pull the agitator up and out of the machine. Now, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see three bolts holding the transmission in place, just remove these three bolts. Now, gently pull the transmission out of the washer and sit it in an upright possition. At this point you will see the clutch assymbly on the top of the transmission with the agitator shaft going through it. There is a spring clip holding the clutch in place be sure to wear eye protection. Just pop this spring out and remove the entire clutch and replace with new clutch assymbly. Re-assymble the washer and the problem you are encountering should be solved. Happy to help, Tim.
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
How long have you owned this unit? If it is new I would look in back for yellow straps and yank them out as they are shipping straps, If it is old I would get it to that point of dancing and stop the machine and check for water in the basket. If this doesn't get it I would pull the machine out and tilt it back and look at the four springs supporting the tub to make sure they are attached especially the one in the back that goes tub to frame. If it is an old but faithful machine suddenly acting this way I suspect basket alignment from a corroded block drive, damaged agitator and holding the lid switch so you can watch the spin will pin point this problem. Another is slow spin from a worn timer leaving water in the clothes, you would know because the clothes wouldn't spin out 100% of the water. Finally older machine can get a sledgy deposit in the back bottom of the tub close to the center causing a unbalance usually marked by a smelly machine that leaves black marks and spots on clothes. Please get back after you have this food for thought.
