Question about Panasonic AG-DVX100 Mini DV Digital Camcorder
External dv disconnect
Will not let me record
My Panasonic AG-DVC30 has everything installed and battery fully charged along with the DV tape installed I press record and it tells me "dv external disconnect" what gives? what good is the battery then? can you clarify?
Posted on Sep 10, 2019
6ya staff
SOURCE:
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
I can not select input source, even though AV1 is connected. Pressing INPUT button has no effect. All I can see is ''Not connected to the camcorder'', which is true - but I want to record from AV1.
Press INPUT repeatedly to select the external input
to record from.
DV IN jack.
This recorder is only compatible with DV-format
(DVC-SD, DV25) camcorders. Digital satellite tuners
and Digital video recorders are not compatible.
Make sure your cables are connected correctly, if an audio cable is plugged into the video the unit wont see it.
Sep 05, 2009 | LG RC897T DVD Recorder/VCR Combo
Dvx100b
You have to go into your menu and turn the dv setting to off. This setting as it is now thinks you have an external device connected via the firewire (like a hard drive FS100) so, go into the recording settings on the menu, scroll down to 1394 or dv and turn this setting off.
Jul 07, 2009 | Panasonic AG-DVX100 Mini DV Digital...
No sound when recording
Please get your microphone tested, also, you can try testing the recording using external microphone.
It seems that the problem is with microphone contacts or internal loose connections.
Seem to be a minor one, hope it will be resolved with above methods.
Thanks.
May 01, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
I own a Panasonic PV-GS31 Mini DV Digital Camcorder, I am a Private Investigator and while recording the sound needs to be muted, how can I accomplish this?
Hi There, There is no external mic input on that model camera. The only way to do it is you will have to take the front panel off the unit and disconnect the flat mic/audio cable from the front panel. If you do this, tape up the connector so it won't short out the unit. If you had external mic in, you could put a dummy plug in and that would cut the sound from the internal microphone.
Thanks, me cicmo
Dec 02, 2008 | Panasonic PV-GS31 Mini DV Digital...
Turn the sound off for recording on PV-GS320 DV camcorder
Hi, I think the PVGS320 has an external mic input. Plug in a 3.5 mini dummy jack and that should turn off it internal microphone.
Nov 15, 2008 | Panasonic PV-GS320 Camcorder
Recording From Underwater Camera
I have a gs11EB. I don't it's possible to record into this camea from an external source?????
Jul 03, 2008 | Panasonic NV-GS11B Mini DV Digital...
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
panel.
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Panasonic agdvx100b
Since it doesnt sound like you have a special external firewire hdd recorder that can direct connect to the camera, you gotta capture it with your pc and send it to your hdd after. Watch out that most of those hdd are set (partitionned) as they cant transfer file bigger than 4.xx gig... (You can usually set file recording from your pro capture software that built multiple file no more bigger than 4 gig per file...
Oct 25, 2007 | Panasonic AG-DVX100B DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Panasonic AG-DVX100 Mini DV Digital Camcorder Logo
110 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
