HP LaserJet 1200 Printer Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Light black line on left side of printed pages.
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Jun 12, 2009
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006542
Points
9738
Pull out the toner cart and look at the drum....it should be clean. If it is clean, you have a worn out fuser, if it's dirty you need a new toner cart.
Why is it when using black it only comes out grey on the far right side
remove toner and drum unit
remove toner
check to see if there is toner in the drum unit if not fill unit run 5-10 prints
replace dev roller
replace drum cylinder(opc)
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
1helpful
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
4helpful
2answers
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
2answers
1helpful
Line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Cs-2030 leaves a black line on left side of page...
The waste bin might be full,try emptying it. Also check the photoconductor unit
Light grey vertical line printing on left side of paper used the cleaning cycle and line in now doubled There is a black vertical line down left side of the page. I used the cleaning page but the line is...
I believe there are 3 possible causes for this issue; toner drum, fuser or transfer roller - more than likely I would dismantle the printer and check for lines on the fuser. But just in case remove the toner and carefully release the flap to reveal the toner drum - if that is scored and the lines correspond to those on the print-out thats the cause.
Rgds Colin
k24674
Grand Canyon Tech
Grand Canyon Tech
