Apex Digital PF3230 32" TV Logo
Posted on Jun 11, 2009
Conversion I have an Apex ModelNo. A727285 and don't know if it's digital or not. Have no manual for changing over. What can I do
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
55
Points
Does the remote have a dash or dot button on it? if so it has the digital tuner, you need the dash or dot button for the digital channels such as 2.1 2.2 7.1 7.3 etc...
I need to know how to change modes without controller when I'm using a dvd
Without a remote controller, you may have limited options to change modes on your Apex digital TV. However, you may be able to change the mode by using the buttons on the TV itself.
Here are some general steps you can try:
  1. Turn on your TV and make sure your DVD player is connected to it.
  2. Look for the "Menu" button on the TV and press it.
  3. Navigate through the menu options using the arrow buttons on the TV until you find "Input" or "Source."
  4. Press the "Enter" button to select the input/source option.
  5. Use the arrow buttons to select the input/source that corresponds to your DVD player.
  6. Press the "Enter" button to confirm the selection.
  7. Press the "Menu" button to exit the menu.
Note that the specific steps may vary depending on the model of your Apex TV. You may also consult the user manual for your TV for more information on changing modes without a remote controller.
1helpful
Apex Digital DVD Operating Manual
Manuals Lib has the user's guide for the Apex AD-600A here: https://www.manualslib.com/manual/209859/Apex-Digital-Ad-600a.html . The operating manual is here: https://www.manualslib.com/manual/979777/Apex-Digital-Ad-600a.html . You can download either manual from the above links by clicking the link for Downloading the manual near the upper left of the page. You will need to confirm that you are not a robot.
I hope this helps.
1helpful
2helpful
2answers
The philips universal remote codes for my apex tv don't wok. Since I put new batteries in none of the codes for apex tv work
Hello
Philips universal remote control cannot be synchronised with Apex Digital TV. There is no code for Apex with it. There are very rare remote controls which have codes with Apex Digital. Comcast On Demand Custom DVR 3-Device Universal Remote Control is one amoung them. Codes for Apex Digital Tv; with this remote are:
0748, 0765, 0767
Buy this one. It can be sychronised with most of the present devices. OK.
Help with my tv
I don't know what you mean by "good". I've worked on this set several times for different problems. What do you need ?
1helpful
2answers
Finding a code
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
1helpful
3answers
Manuals
Jason,
Who is the manufacturer of your player??
APEX TV don´t work
Try pressing the "F" or function button and hold while pressing the Mute or "M" button at the same time. Hope this helps.
3helpful
2answers
TV Locked!
Turn on the TV With the remote press the F button and the Mute button at the same time. This should bring your TV back to normal mode. from Don "the TV King"
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
