I have a Lg ce 0168 phone. But I am unable to access the phone because I totally forgot the security code Number as I used to operate so many PIN and Code numbers. I've tried several times but I can't get through. It kept on requesting me to Enter the Security code number which I do not have any other numbers to enter.
The ONLY access I have with the phone is to receive incoming calls apart from all other access of the phone. I even tried these default codes like 0000, 1234 and 1111 but of no success.
Please help me solve this problem.
Thanks so much..
Danny (Papua new Guinea)
تليفون ال جى ce0168 ومش عارف افتحه ونسيت الباسورد
First enter ##3283# on the main screen as a phone number.
a scren will appear, scroll all the way down to Advanced.
then another screen will appear, go down to Lock Code and hit the enter button.
the current lock code will appear
remember it!
then go to settings/tools
go down to More...
then go down to Security and enter the code that u were to remember
then go to change lock code
Their is no easy fix unless its the 11 digit puk code that you need but it dint sound like it it but if you take it to a phone repair shop they should be able to plug a flash lead in adn reset the code for you should cost no more than a fiver to do sorry i couldnt be any more help but their is no way round it without having the flash lead and the programme for that phone hope this is some hwelp though.................
Original code is : 0000 if you have secoudn hand phone you must probably use computer and some program to change the code.
On my LG KG 800 original security code works
SOURCE: LG CE 0168 phone security code Lock
have you left the phone off for 24 hours if you switch it on and it is asking for security code i can get the master override code for your phone but i need the imei number and the code number off the back of your phone under battery the imei is 15 or 16 numbers long might be like123456/44/22343/2 and then the other one is about 6 numbers long 123456 if you give me these i can give you master code if your phone dont ask for code then you need to get it flashed at a shop to unlock it hope this is some help
If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
http://www.lgunlock.net/LGunlockinstructions.htm
thank you i found reset number here
plz inform and give some money me
[email protected]
security code for lg ce 0168
THE phone wont open without a security code,only access is for emergency calls.
hi...
I have a Lg ce 0168 phone but i can get my security code...
can u help me solve my problem?
please
Hi
I want to reset my settings on the LG KG800 but I don't know the security code.
Thank you
as soon as phone switches on asks for security code,has no other functions apart from emergancy calling
i went the code number to decode my lg 0168
have kg800 choc phone forgotten security code please help?
lg touch screen pink phone need puk code
i forgot my code
Hi, Hope you can help me out, please help me to unlock the phone, Details are:LG ce 0168 IMEI: 358189040987413. Thanks so much in advance, can't wait to walk back in the store
end i
end i
Please i need lg CE 0168 factory number i lock mine and i coulnot be able to unlock it helf me out
