Question about Westinghouse LTV-27w7 7 in. LCD HDTV
Service manual for LD-3235
Ld-3235
4 Suggested Answers
6ya staff
SOURCE:
cbfra
SOURCE: westinghouse ld-3235 picture goes in and out
I have the same tv and had the same problem.
If picture appears when you slowly hit back of the tv, then the solution is quite easy.
1-There are 2 small lids on the back of the tv, open the one at the top with using a screw driver.
2- there is a connector on the top, make sure that it is connected well.
As far as I understand there is somehow a connection problem or maybe result of oxidation or something.... 5_3_2012_9_06_22_pm.jpg5_3_2012_9_06_40_pm.jpg5_3_2012_9_06_54_pm.jpg
Posted on May 03, 2012
cbfra
SOURCE: westinghouse ld-3235 led tv no picture but have sound
http://www.fixya.com/support/t10640288-westinghouse_ld_3235_picture_goes_in_out
did you tried that?
Posted on May 04, 2012
Lawrence Oravetz
  • 10543 Answers
SOURCE: Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Posted on Jan 09, 2014
Necesito el c?digo de tv westinghouse modelo LD 3235 serie 6441y13001535
The applicable code would be in a compatible remote control.
May 04, 2017 | Westinghouse Televison & Video
My lg Le 1415m1 has limited flow pressure have replaced wash pump motor still did not fix
LG LD-1415M1 Support: Find Manuals & Warranty Info ' LG ...
www.lg.com/au/support-product/lg-LD-1415M1
LG ElectronicsProduct Support. Home Appliances; Dishwashers; LD-1415M1. LD-1415M1 ... What should I do Low Rinse Aid indicator lightens up? Why is water not supplied ...
LG ElectronicsHome Appliances; Dishwashers; LD-1415M1. LD-1415M1. Search For ... What should I do when dishes are kept in a dishwasher after a cycle? Are plastic or ...
Nov 19, 2015 | LG Dishwashers
Westing House LD-3235 will not scan
It could be the tuner but you have a few options.
First is unplug the set and or a cable or sat box and wait a while. Plug back in to see if set/box will reboot.
Another option if you have or get a Box is get one with the audio/video output jacks on the back and connect it to the same type on the rear of your set-----Bypass the tuner and operate via that input changing channels on the box.
May 27, 2012 | Westinghouse LD-3235 32in LED 720p Flat...
Westinghouse ld-3235 led tv no picture
t con board on the back of the screen will need replacing, its the one with the wires going to it from the main av board to the screen. the chip can become damaged due to heat or even come away from the board. if its working when you bag the board it could be a lose connector or the connections that is soldered to the board have come away and will need soldering back on.
Jun 05, 2017 | Westinghouse SK-32H540S 32 in. LCD TV
Keep getting error code Ld what does this mean
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by the control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for proper pumping.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Post your model number I might have a service manual and a better answer for you.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 22, 2011 | Washing Machines
Looking for a holden astra LD 1989 workshop manual
  • Nissan Pulsar N13 and Holden Astra LD 1987 - 1991 Workshop Manual Repair Manual for Nissan Pulsar N13 Series & Holden Astra LD Series ... N13 and Holden Astra LD 1987 - 1991 Workshop Manual ... 1987, 1988, 1989, 1990 and 1991. Holden Astra LD ...www.automotobookshop.com.au/gregorys-?nissan-pulsar... - Cached
  • Dec 07, 2010 | Nissan Pulsar Cars & Trucks
    Aficio 400 code SC323
    Laser not enough power, due to aging
    It must be replaced.
    Jun 04, 2008 | Ricoh Aficio 1035 Copier
    Westinghouse LTV-27w7 7 in. LCD HDTV Logo
    171 people viewed this question
    Top Westinghouse Televison & Video Experts
    CoppellTVRepair.com
    Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
