SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
SOURCE: Samsung CLX-3160 FN
Easily Solved! I've got the the Samung CLX-2160 and I have was getting the same message "Replace/install Waste Toner Tank". The first thing I asked myself was, what is the 'Waste Toner Tank'? After typing in into google, I realised that the 'Waste Toner Tank' is the grey colored part located to the left (If you're facing it) of the toners barrel. So all you need to do is take the Waste Tone Tank out, shake out all the waste tone from it and replace it. Your printer will be up and running like the first time!!!
