My Panasonic PV- 9450 ate a tape & now I'm afraid to try another tape *: (
Hi Melanie -
First, you should keep away from the T-160 tapes as they are thinner and more likely to jam. The T-120 or less sizes are better. Next, use high quality name brand tape - not the off-brands found in the bargain bin.
Do the regular maintenance. All tape is "dirty" (including cassette, 8 track, reel to reel, etc.) and will deposit dirt on the tape heads and "transport" mechanism. Transport consists of capstan and pinch rollers that push / pull the tape in and out of the housing. when dirty, they slip and interfere with the "pick up" of a quality picture from the tape. Use of a quality wet cleaning system at regular intervals (or whenever picture quality deteriorates or tapes jam) is highly recommended. Here are some googled results for wet VHS cleaning systems:
http://www.google.com/search?q=wet+vhs+tape+cleaner&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&channel=sb#channel=sb&q=wet+vhs+tape+cleaner&rls=org.mozilla:en-US:official&safe=off&tbm=shop
SOURCE: Panasonic VCR Displays "REP"
Press "Action" on your remote control. Go to "Play repeats" and turn it off. "Play" will then replace "Rep" on your display.
SOURCE: panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
SOURCE: Panasonic VCR Pv-4611,When pressing Play,Vcr Lock
it should be on your remote or in the menu set up
