A
Anonymous Posted on Mar 03, 2014
Teac mms51 set up
How to installed
Larry Ng
Level 3:
Top Expert:
  • Sony Master 14,567 Answers
  • Posted on Feb 25, 2020
Larry Ng
Sony Master
Level 3:
Top Expert:
Answers
14567
Questions
0
Helped
3274595
Points
66484
RTM
Leo?
a speaker system . it does have a manual
I see support at maker nor manual laying about on the web sorry
install to what, name what you are doing.. first.
the speakers plug into them selves with wires cables
then the big speaker need power cord/pack to AC power
then the 3.5mm port on speaker (LINE-IN) goes to PC line out green jack,
1helpful
My 83 mother wants me to set time on her Teac 180 alarm clock?
Hello Hellen Barnett
The "time / set" button is the key to success...
(observe & restore the "lock/run" status when finished)
I could not find your SPECIFIC manual...
but I take strength in the knowledge that once
TEAC has a good design they generally stay in that area.
Take a look at the TEAC CRX188R owner's manual below
Location of Controls (Pages 4 & 5)
Teac CRX188R User Manual Page 4
Teac CRX188R User Manual Page 5
Carnac the Magnificent
Teac 6010 reel to reel makes static when not playing.
These units are old enough to need new electrolytic capacitors installed in them. I have seen wind like sounds and frying eggs type sound that are all resolved by a new set of caps. These things are from the Vietnam war era and when I was at Teac in the 80's they were considered old then.
1helpful
2answers
I need the jumper settings for a fd-55-bv-16-u drive to be used as drive "a" in a two drive system. I have no manual and want to install into an old XT
Here is a link to the manual for the FD55-BV drive. The jumper settings are found within:
www.bitsavers.org/pdf/teac/FD55BV_Spec.pdf
4helpful
2answers
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
Teac digital set top box prompt every five seconds
I had the same problem - pretty easy fix. You'll need a usb flash drive with all other files removed. Go to following link:
http://www.teac.com.au/pages/hdb842softwareupgradever161008
Print out the instructions and make sure you have winzip installed on your computer. Instructions were pretty easy to follow and seemed to fix the problem. I haven't watched the TV for a long period of time, but it seemed to sort out the problem you described and system seemed to run better than previously eg. didn't hang - receception better.
Good luck
55helpful
3answers
TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
1helpful
Teac dvd rom
CLEAN IT LENS BY A LENS CLEANER OR GET IT CLEANED BY A PRO..
TEAC floppy drive won't work with Vista Home Premium
Have you tried WWW.Driverguide.com - Generally I have found all the drivers I need there. Else try the manufacturer's web site at www.teac.com
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
