SYLVANIA LC200SL8 ? 20" LCD-TV Settup up channel setup
This is the chanel set up options I see on the online manual:
- CHANNEL SETUP -
ADD/DELETE(DTV)
AUTO PRESET CH(DTV)
AUTO PRESET CH(TV/DTV)
AUTO PRESET CH(CATV)
! CATV takes approx. 50min.
To set up for over the air broadcast that local channels now have in HDTV, you will select AUTO PRESET CH(DTV). You will have to disconnect cable for this option; however, the cable company will send local channels over the cable.
Bottom line, if you have cable, use it, it will most likely still deliver the best signal.
So coonect cable and use this option:
Oh, and the reason it takes so long is because there are more channels to scan with cable then with the local over the air channels.
