DST (Drive Self Test) failed. this simply means that the drive is no longer stable. If you are unable to boot to windows or safe mode and this is the error you get you might need to do a low level format if you still want to use it or do a debug script then repartition and re-format the drive.
The Low-level partition - will reinitialize your drive to the factory settings.
Debug Script - removes DOS and non-DOS partitions on the hard drive. It also allows you to convert a drive from an incompatible partition structure to one that will work with
FDISK.EXE such as, converting Linux partitions to MS-DOS partitions.
For you to use the Low-level format and to completely wipe out HDD data. Use the format software from
http://www.killdisk.com, download the CD ISO image , burn to CD, ad boot from CD , the rest can be found in the menu.
In using the debug script use this :
Insert the boot diskette that contains the Debug command into the respective drive.
Restart the computer.
A black screen with Microsoft Windows® 95 Startup Menu will appear. Press the <5> key on the keyboard followed by the <Enter> key. The boot process will conclude with an A:\> prompt, followed by a blinking underline (cursor).
From the A:\> prompt, type the following commands and press the <Enter> key after each command:
NOTICE: Performing the following will remove all data from your hard disk drive.
NOTE: Type the bolded text only (the debug prompt is a dash). You will receive an error if you type anything other than the bold text. The non-bolded text represents the system response that will appear after typing each command and press the <Enter> key.
debug
-F 200 L1000 0
-A CS:100
xxxx:0100 MOV AX,301
xxxx:0103 MOV BX,200
xxxx:0106 MOV CX,1
xxxx:0109 MOV DX,80
NOTE: Type 80 for the Main hard drive - HD 0, or type 81 for the Second hard drive - HD 1.
xxxx:010C INT 13
xxxx:010E INT 20
xxxx:0110 (Leave this line blank and press the <Enter> key)
-G
The message, Program terminated normally, appears. Turn off the computer by pressing the power button.
On the next startup the hard drive must be partitioned and formatted.
Hope this helps to save your drive.
