JVC HX-C6 Shelf System Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Protect comes up on my hx-c6 - JVC HX-C6 Shelf System
Anonymous
Level 3:
  • Master 2,071 Answers
  • Posted on Jun 12, 2009
Anonymous
Master
Level 3:
Answers
2071
Questions
Helped
1014787
Points
5371
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Protect comes audio
Unplug the speakers from the stereo, then try and power it on. If your problem continues, check the internal fuses on the stereo.
To fix a hx-c6 sterio system When i cut on the system. The light comes on and say protect. I would like to know what is the problem and to fix it.Thank you.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
HOW TO RESET MY JVC HX-C6 FROM "PROTECT" MODE
Resolve the threat and it will stop protecting itself.
Sadly, the manual doesn't address it directly.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-HX-C6J-manual/id/314bh349/t/2/
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
1helpful
Jvc hx-c6 is in protect mode help
check speaker wireing if thats not the pro then u may have over heated the unit.the stk xxx exc are pro bad youll have 2 open that bad boy up.
1helpful
JVC HX-C6
Hello, Yes you can, if they are the regular speaker wire (2 wires--black+red or something similar)
My brother connected my HX-C6 shelf system to the pc and now it turns off and says PROTECT.
sounds like he may have run the wires from the computer speaker out plug instead of the line out plug. Check that by plugging headphones into the back of the computer where the cord is. If the sound is loud through the headphones, try plugging them into the other out plug. The correct plug will not have much volume at all through the headphones. Try this and let me know if it helps :)
12helpful
5answers
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Protect
The audio amplifier of your device are damaged and you need to replace him.Good luck
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
