Ryobi Multi-Volt Battery Charger Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 18volt Ryobi battery needs the inside batteries replaced. Is there a cheap way to do it? Can I buy just the inside batteries for my 18 Volt?
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Jun 12, 2009
Anonymous
Expert
Level 2:
Answers
104
Questions
0
Helped
62903
Points
195
Yes you can replace the inside batteries yourself , just take the old ones out and go to Battery world or a similar shop and get replacements then all you have to do is repack them yourself and put them back into the battery case .
1helpful
2answers
Can i charge a 18volt ryobi battery on a 14.4volt charger
you can but it will take longer to charge and prob will be at 16 volts give or take 1 volt.
2answers
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
Have a great day.
1helpful
I can't find the owners manual to my Ryobi 18 volt chainsaw. Can I get one online? If not, then where?
Hello Tom, Here's a link to the Ryobi US web site with a free downloadable copy of the manuals for bothe the Ryobi electric chainsaw and a copy of the manual for the 18 Volt Battery versions
Electric Chainsaw
http://www.ryobitools.com/product_manual/file_url/252/RY43006_640_eng.pdf
18Volt Battery Chainsaw
http://www.ryobitools.com/product_manual/file_url/254/P540_P540A_P540B_eng.pdf
I included both, just in case you have a corded version too, since sometimes the Fixya site provides "fill in" information for askers.
I hope you find this Very Helpful and best regards!
18 volt batteries
Yes you can, as long as the batteries are the same style and fit the older Ryobi tools. The Ah rating is a capacity rating. The higher the Ah, the longer the battery will last so the 1.7Ah will just last a bit longer than the 1.5Ah batteries, but yes you can use them on older 18v Ryobi tools. I do it all the time.
1helpful
2answers
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Why does the Dewalt 18V DW9096 XR+ Battery have 3 contacts?
the newer type of battery had an electronic inside only. older style battery had sensor only.
3answers
Battery charger model 1400666 not charging The red led is not on.this is a 12 volt charger.
I have two 18volt chargers doing the same thing. I have had them apart and it seems to be the transformer not pushing any power thru. If you can find a transformer that fits and has the right voltage that should fix the problem. From what I can make out if you leave the battery in for too long on charge it cooks the transformer. Hope this helps
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
