Hi everyone, I had an old memory card and it kept saying card is full after taking 100 pics (2gb), so I ended up buying a NEW SD card 64gb but it STILL says that the card is full. I've formatted it on the camera itself but I can't take any pictures. Is it the card or the camera do you think??
I ran into this exact issue (64GB Sandisk SD not working with an old Nikon D40). The problem is that the camera requires FAT32 formatting, which is not supported on partitions greater than 32GB (i.e the 64GB stick). A format from the camera attempts to repartition all device space (64GB) which is incompatible.
I solved this by connecting the SD to my laptop, opening the windows disk management utility (diskmgmt.MSC), deleting all partitions on the SD (right-click, delete partition on all allocated space), the right clicking the unallocated space, add simple partition, then allocating only 32GB and using FAT32 as the format (any more and windows will only provide exFAT as an option, also not compatible with Nikon D40). Plugging that into the camera and NOT reformatting from there worked.
Are you sure it is full, did you put it into a computer to check? Maybe the picture resolution is very high or you have videos and there is more than 2Gb worth of photos.
SOURCE: memory card malfunction
Pictures can sometimes be recovered by sending the card to a service provider, or by downloading software designed to recover the pictures from the card. It is not clear weather the problem is the card or the camera, however to recover the pictures from the card would be the same process. If you do not have one you will need to buy a USB card reader to load the card on the computer. Consider buying another card to test in the camera, if you so wish. If the camera is new enough also consider contacting the manufacturer for warranty assistance. David Millier Advance Camera Repair
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
I had the same problem with my CoolPix5400 and this resolved the issue.
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
SOURCE: my nikon coolpix 5700 is saying it is out of
Did you format the card in the camera before trying to use it?
no the sd card is not being read and will not go to cpy mode 2mve from intrn to card
L100 not D40
