I have had my treadmill model NTL09707 for approx 10 years. Never an issue. Moved it down the hall to a different room. Disconnected power in rt vertical rail. Disengaged shock and had to move base on its side into room. Set back up reconnecting what we disconnected and now no power. No display thing. Tried reset button. Disconnected and reconnected power in rt rail, only plugs in 1 way. Took apart console, all looks connected. Took off lower lid on base to look at power board to see if there was an obvious issue. There is a red light, that illuminates if you wiggle the reset button and wiring. Help
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
SOURCE: nordic track exp 1000 treadmill console
Hii sumazone, was just wondering if you ever found out what was wrong?? I am havng same problem. thank you
