First, make sure you're in the manual exposure mode, not manual focus mode, as set by turning the mode dial to the "M" position. In manual exposure mode, turning the main command dial should change the aperture, while turning the subcommand dial should change the shutter speed. If the two command dials don't have the expected effect, reply to this post and we can troubleshoot further.
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode. If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Hello mehran_vafae,is supposed tohaveputaDX lens. The mode dial,selectin what wayis goingtotake a picture. Youcanmakecombinationsaccording tothe modeset in themodedial,withtheFn key/commanddial,commanddial/apertureAmode,commanddial/shutterspeedSmode,FullAuto/+/-compensationsw,etc... Pleasecarefullyreadtheusermanualsuppliedwithyourcameraandif it failstake them toNikon service. Regards
Does the "unlock" button depress? When my dial seemed to freeze, or turn very hard, I lightly coated a small piece of newspaper with petroleum jelly (both sides) and slid it all around under the dial. This lubricated the plastic and made it turn freely. Good luck!
