When I press the eject button the display comes back on. Everything seems to work ok
SOURCE: pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
SOURCE: Display is not working
First try cleaning your faceplate contacts with a q-tip and some alchohol while the power is off. if this is not it you may need a new ribbon cable that connects the face to the main unit. try pacparts.com or pioneer parts or even ebay for the part.
SOURCE: OEL Display not Working on my Pioneer DEH-P7800MP
go to ebay.com search for (deh-p7800mp ribbon) face paate ribbon is probably bad i got one fixed it right up.
SOURCE: I have a Pioneer DEH-1730R
That sounds like your radio is going into protection mode. I would disconnect your speakers one at a time and see if your sound comes back on.
SOURCE: when i press the eject button it comes in the
Did you press the button briefly or did you hold it for a few seconds. To eject just press the button quickly. Pressing it for a few seconds is tilt.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears. The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
