Hi ,
When i press start the water starts to fill then stops for a second then starts again then stops and starts
( on and off at about 2 to 3 second intervills ) then after about 30 seconds to a minute the michine beeps and stops as if to say that the load is complete . I have takin the taps off the machine and water runs through them no worrys , i have takin the filter screens out and cleaned them not that they were dirty anyways. i have tapped the soliniods , I have done the hot cold test and both the hot and cold do the same thing , and warm . Was wondering if it might be posibly the water level switch ? ? Any ideas please ?
Thanks for your time ..
Robin .
p.s Sorry about spelling .
I had this problem - fixed it using the advice I found here; http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=33339&sid=c718bb2d59f889d27d44d7dd5b9db3b1 - turned out to be the balance switch.
Well where to start .....
This brand has a hell of a lot of quirks.
The first thing to try is this : With the power on at the wall and the machine off ,push and hold down the start button , then push and hold down the power button you may hear up to 3 beeps at this time (hold down the buttons for 5 seconds then release) turn machine off and turn it back on and just push start button.
What this does is re programes the computer ,then just leave machine to run cycle
Well i hate to say it but the bottom half of your computer in the F&P has shat itself .
The next step is to replace it, the cost of these units is around $200.00 AU, just for one half.
The only cheap solution to this is if you can get one from the dump and it works for you.
These are a very simple plug and play design so you can't get any wires mixed up when changing the units.
Hope this fixes your problem.
hey , i tried your solution to my problem with the fandp smart drive , i went through the prosess to re programe the computer , but nothing really changed , it still surges on and off with the water intake , i tried to scip to rinse and spin and noticed that the machine surges on and off on these cycles also . stays on for 2 secs then off and so on and so on . What should i try next ?
