Televison & Video Logo
j
joanne peatfield Posted on Mar 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Subtitles on tv no remote to get them off cant get code for a new remote model no 3241ts
Ive got a tevion tv model nunber 3241ts lost the remote and subtitles are on screen how do i get them off without using remote and also what is the code for the tv when i get a multi use remote
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 05, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007063
Points
237762
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
5 Related Answers
Anonymous
  • 95 Answers
  • Posted on Mar 13, 2008
SOURCE: sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
A
Anonymous
  • Posted on Nov 01, 2008
SOURCE: tevion television
tevion uses the same codes as "Konka".. if your universal remote has codes for konka, then it should work.
Anonymous
  • Posted on Nov 08, 2008
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
Anonymous
  • 1124 Answers
  • Posted on Sep 23, 2009
SOURCE: Code to progarmme Tevion TV
Might be a bit late - but I hope this helps..
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on Oct 08, 2009
SOURCE: how do i turn off the subtitles on my toshiba
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
1helpful
WHEN MY FRIEND'S TEVION TELEVISION MODEL No. 3241TS IS TURNED ON, A PICTURE FLASHES ON THEN DISAPPEARS. SOUND IS STILL ON BUT NO PICTURE. THE SAME APPLIES IF CONNECTING AND PLAYING A DVD.
That sounds like the inverter board. I would go online and search for the inverter board for that model TV. Replacing it is a very simple task once you take the back of the TV off.
2helpful
2helpful
2answers
Tevion LCD3210ID remote codes - Please Help
i cant get anything on my tevion television/dvd
Have a universal remote and want to set it cus i cant get tevion
Good luck..
3helpful
2answers
Need password for tevion tv/dvd cant go or do anythink have to en
try 0000 that is always the default for everything i buy
I need a code for a tevion universal remote
Good luck..
Tuning sky into the tevion 3241ts
Customer Support are taking peoples names when thay have the code for Tevion model 3241TS, they will either call you or email you with the code, reference hissing on low volume, yes my set does this, I have called Support Services, they do a one for one exchange, i.e. a courier brings you a new t.v. and takes the old one away at the same time, I'm in the process of doing this now.
Thanks
Steve
25helpful
9answers
Good luck..
23helpful
10answers
Universal remote codes for a conia tv?? Help me PLEASE :)
Thank you guys! just bought our universal remote control and now we able to use 1 remote for everything especially our conia plasma tv and it really works the 0821 code...
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
