Question about Medion Computers & Internet
Unable to send e-mails using windows mail
Following error message appears "the connection to the ser4ver failed server Mail.talktalk.net protocolSMPT port 25 secure ssl no.error10051, error number 0x800ccc0e
  • Medion Master
  • 27,725 Answers
The connection to the server has failed. Account '<account name>', Server: '<SMTP server name>', Protocol: SMTP, Port: 25, Secure (SSL): No, Socket Error: 10051, Error Number: 0x800CCC0E
To resolve this behavior, change the SMTP server for your e-mail account to use the MSN SMTP server. To do this:
1.In Outlook Express, click Accounts on the Tools menu.
2.Click the Mail tab, select the account that you want to change, and then click the Properties button.
3.Click the Servers tab.
4.Under Server Information, delete the entry that is in the Outgoing mail (SMTP) box, and then type smtp.email.msn.com.
5.Under Outgoing Mail Server, click to select the My server requires authentication check box, and then click the Settings button.
6.Under Logon Information, click Log on using.
7.In the Account name box, type you MSN Member ID (everything before the at sign (@) of you MSN e-mail address).
8.In the Password box, type your MSN account password
9.Click to select the Log on using Secure PasswordAuthentication check box.
10.Click OK to close the Outgoing Mail Server dialog box.
11.Click OK to close the <Mail Account> Properties dialog box.
12.Click Close.
Posted on Mar 06, 2014
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 45 Answers
SOURCE: I just got done setting
Since you have not signed up for Yahoo Mail Plus, they do not allow you to use another program to access your mail. They want you to use their WebMail Page so that they can serve you ads to pay for their service. They have an excellent Email Web Page, so it's a small price to pay.
But if you really need POP access and don't want to pay to get it, you could consider using Gmail. They allow POP access for free. Just setup a new Gmail account and go into the settings on the Gmail Webpage. From there, you can enable POP access. Be sure to write down the server information you will need to enter into your Email Program.
Good Luck with whatever choice you make!
Posted on Aug 29, 2008
Anonymous
  • 40 Answers
SOURCE: The connection to the server has failed. Account:
You can also receive this error message when you have antivirus e-mail protection or personal firewall software enabled on your computer.
Try disabling the antivirus program through msconfig or close the antivirus program and see if you get the same error again, if not then disable email scanning and this will help you.
Posted on Oct 04, 2009
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
I have my gmail emails forwarded to my MS open mail. while i receive my emails i am unable to send any emails. i get the following error message. Connection to the server has failed. Server...
The combination of port 465 and no SSL will never work. You must either enable SSL with port 465, or else try a non-SSL port like 587 or 25. What mail program are you using?
Jan 26, 2018 | Computers & Internet
Sending bulk mail to Yahoo
the error message means that the person or persons you are sending the mail to have problems with their mails so try sending it batch by batch or use a mass email sender software
Apr 28, 2010 | Yahoo Mail
Getting the following message from windows live mail, any help appriciated Unable to send or receive messages for the email account. The connection to the server has failed. Server: 'mailin.manx.net'...
The most likely explanation is that your ISP (manx.net?) server is temporarily down. You can connect by webmail?
If it is manx net then you can try accessing your e-mails by logging in on here.
If you can access through web browser, but want to set up windows live mail click here.
Settings for manx.net - for Windows Mail but same will apply in Outlook.
Hope it helps.
Mar 21, 2010 | Microsoft Computers & Internet
Remove emails from mail talktalk net they will not delete
go into your mail setting under outlook or whatever default program you are using and go under tools, rules and alerts and create a rule for any email that contains talktalk in the message or body of the message and block them from being downloaded to your server.
Nov 21, 2009 | Microsoft Windows XP Home Edition
"Can't connect to email server, make sure you have an Internet connection"
Whenever a mail server is unable to process an e-mail request, the e-mail fails and the software displays one of the following error messages: Can't connect to email server Progress bar stuck at 0% To resolve this problem go to http://www.kodak.com/go/itg
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
E-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Computers & Internet Logo
267 people viewed this question
Top Medion Computers & Internet Experts
Ekse
Mark Snell
Thomas F. Schneider
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
