Pioneer DEH-P6800MP CD Player Logo
K
KARL BECKETT Posted on Mar 05, 2014
How do I adjust front to rear fade I can't seem to find this in the manual
How to get rear speaker signal from aftermarket stereo
You can fade front to rear in the menu but its not switched it might be fully faded to the front
Cant access the fade controls. Rear speakers are not operable without it.
When the rear output setting is "rear s/p:SW", you cannot adjust the front rear spreaker balance. Go to the rear speaker output from function and select "rear sp/full".
Hello i am rohit i have avh-6850 in my car i want how connect front and rear speaker and subwoofer there only two rc output one is front and other is non-fad & subwoofer tell how to connect front and...
If you only have 2 sets of pre-outs, you will either have to split the fronts into front and rear channels and use the other for a subwoofer signal, or else utilize an equalizer or other preamp that separates out a sub channel. I have an Alpine EQ that I send one stereo pair into, and it sends out front, rear, and sub outs. That allows for front/rear fade, and independent sub level adjustment.
1helpful
How to adjust the speakers to the back only in a suzuki swift
Please try the selection button again (the one that allows you to set the bassetc) and look for FAD or fade option. That will adjust the front or rear volume
3helpful
2answers
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
1helpful
Adjusting front and speakers
Push the menu/sel button, select bal/fad. Pioneers use the same adjustment for balance and fade. push side to side for balance, up and down for adjusting front to rear
3helpful
3answers
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Pioneer car sttereo without manual. front speakers work but rear speakers silent
Press the audio button (A button in right hand upper corner) till you see FADE or BAL press the up down or left right arrows to adjust the fade and balance till all your speakers work.
If they still dont work, check the wiring at the speaker and the wiring behind the head unit to make sure their properly intact and properly grounded.
Audi gama radio, rear speakers have low sound
Hi there
Have you attempted to adjust the "FRONT REAR FADER" Is a control that fades the sound between front and rear.
regards
Graeme
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
