Reading imposible and unable to read the card SD as if the the card SD was (bleep) compromise
If you think there should be important pictures on the card, please don't do a thing till you recovered them.
For that use an external card reader on your computer. If there are no pictures on the card, please try to format it in the camera.
Also, if it won't work in the camera, first try to format it (FAT32) on your computer and then again format it in the camera. Also check you did not switch the card to the lock position.
SOURCE: Is there a maximum SD
I think you mean 16 and 24 GB (Gigabyte), not MB, but those would not be SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If you really mean 16MB, then that would be rather small, not too big. 16MB is definitely compatible with the camera and is mentioned in the manual.
The maximum memory card size mentioned in the manual is 1GB, and that is quite big enough. If you really need more space, then just carry a spare, like people used to take extra film with them on holiday.
Testimonial: "Cheers long pockets I really appreciate your prompt reply and clarification. Sorry about the MB- GB thing,I will go for a 1GB and back card - thanks"
SOURCE: My Lumix DMC ZS7 reads
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
