10" tablesaw just started to
Hi, W/D here.
Unplug the saw first. Raise the plastic around the blade on the table and look first for material around the arbor, particularly slivers of wood. These can sometimes act as a "brake" and cause the machine to rotate slower. Clean out all sawdust and wood slivers. You can get most of it with a vacuum. While you have access to the arbor, rotate the arbor by hand, feeling for excessive resistance. You can lubricate the arbor with a light machine oil. Look at the belt, and test the tension by squeezing the belt toward the other side, in the middle between the pulley on the motor and the pulley on the arbor. It should squeeze in (deflect) about an inch or so, and be tight in it's position. If the quality of the belt is not up to par; if you feel that it is stretched, or is cracked or otherwise deteriorated, replace it. You can get replacement belts from auto parts stores, at a significantly lower price than ordering through Sears. They'll match you up. While the belt is off, blow the windings of the motor out with compressed air. Sawdust infiltrated into the motor can also cause the motor to run slower. Lastly, take a very close look at the blade. A dull blade will cut slower, and this is especially noticeable in wetter and harder woods. Examples of wetter wood would include treated lumber; harder woods would include species like oak. If the blade is dull, have it sharpened, or replace it.
Best regards, --W/D--
