Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Plastic / maybe electrical smell
Just had an issue with our gas range - never had this before, even ok as recently as lunch today. Tonight while heating some food the oven gave off an acrid smell. It was pretty bad, and dissipated as soon as we turned the oven off. Digital clock and interior light all working normally. Not sure how old the oven is, but would guess 10-15 years. Didn't want to pull the oven away from the way because of gas connections. Interior of oven and exterior (aside from not seeing the back) all looked fine.
  • 70 Answers
Personally, I do not cook indoors with gas (outdoor, yes), but any time you have an issue with gas cooking ranges....you need to call a professional. We are connected to Centerpoint Energy and so I would call them. this could be a very serious gas leak issue. You don't say if you are on a propane conversion type, or utility supplied gas. that smell could be your only clue to something not good. Did your smoke alarm or CO detector go off? You could call your local gas company to ask the questions, if there is a warranty for your range, call that store.
You don't say the age of the range. That comes into play as making suggestions. Please error on the side of safety. Get a professional to deal with this.
Posted on Mar 06, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Oven burner doesn't light
Replaced the ignitor on mine 10 mins ago.... Works like it's brand new. You have to remove the bake pan in the bottom of the stove, remove the drawer, and the sheet metal shield protection the connection. Entire job was 10 mins.
Posted on Oct 22, 2008
Anonymous
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
protek480
Craig Butler
  • 1730 Answers
SOURCE: Igniter working, can smell gas, but gas not getting to burner
Gas valve is not working. Replace
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 23, 2009
Old Garland Propane Gas Stoves. Are the pilots today standing or are they electric start?
Most stoves today are electric start. The reason is they are much safer because if the pilot goes out, there is a gas smell which is dangerous. God-Bless!
Sep 08, 2015 | Garland Kitchen Ranges
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
2003 Range rover won't start
Very likely the fuel pump has failed, if you mean you tapped on the gas tank
and it finally started. When a pump fails, sometimes rapping on the tank will re-energize it briefly or maybe even a couple of times before it gives out for good.
If you were tapping on the gas pedal, though, and it just started, your mechanic will have to look at it. Too many electrical fault possibilities, Scott, it needs proper diagnosis to find the p[roblem.
Jun 02, 2012 | 2003 Land Rover Range Rover
JennAir range gas leak
Turn off gas call fire dept. get out of house Gas company will do a free checkup on range to find problem.after it airs out DO THIS NOW. You are At RISK.
Apr 11, 2012 | Jenn-Air...
I have a 4 year old range master classic 110 Tonight both ovens stopped working and the clock does not work also. However the grill works and the hob works.... Any idea as to the problem? I have checked...
Hello Jeff,
it seems to me a problem with the timerfunction of the clock.
Clocks are the most source of problems, so when I refurbish a cooker and the timer does not work properly, I shortcut the timer as new clocks are very expensive.
In that case, the clock itself stays working.
For doing this, you need to lift the hob.
BE CAREFULLY, AND BE SURE THERE IS NO TENSION ON THE COOKER
I hope this will help you and I wish you a good weekend and a nice meal with your friends. Dik
Jul 20, 2017 | Rangemaster Classic 110 (Dual Fuel) Dual...
I live in an old building and today there is a strong gas smell coming from my base board heater in the living room. I'm not sure if it is electric or gas. There is water like knob inside of it but there...
The heater you're concerned about is an Electric Heater. So, I'm not sure why you're smelling gas. Is it a rotten egg smell or more of a plastic burning smell?
Feb 25, 2011 | Fahrenheat LFP6152 Halogen Baseboard...
I have an intake leak where the 2 gas lines go into the intake, what would cause this and how do i repair it? the engine was recently removed and replaced if that helps and it is on a 1998 chev tahoe with...
you will have to remove upper intake plenum the black plastic part there is a o-ring around the area you are speaking of. now if this engine didn,t have the intake gaskets replaced before installing now would be good time because if you keep vehicle believe me you will have to do sooner or later these engines came with plastic intake gaskets that are notorious for leaking to do this you will njeed to remove both upper and lower intake manifolds I just started a job on 99 tahoe today before lunch and customer is driving tonight replaced upper and lower intake gaskets fel-pro makes updated gaskets for this engine that has thick metal shim and rubber gaskets a great improvement that ends this problem as for your vacuum leak at opening for fuel lines don,t see often but is possible hope this helps
Mar 29, 2010 | 1998 Chevrolet Tahoe
I've had a Premier electric stove for a number of years and just today i'm noticing a smell coming from the oven that resembles gas while preheating and cooking. Any idea why?
Either the ignitor is wearing out and not drawing enough amperage to open the gas valve properly, or the gas valve is not working properly. You can not tell a weak ignitor by looking at it, you need a amp clamp to test.
Do not recommend using any appliance with a gas smell coming from it.
If you are smelling any type of gas when not on, turn off gas to appliance completely.
You state this as a electric stove, taking this to mean electric ignitors and not pilots............
Feb 28, 2010 | Kitchen Ranges
Kitchenaid selectra oven range: Electrical smell
If this is a new range the odor is coming from the binder used to install the insulation in the range. You would need to put it through a self clean cycle of at least four hours to burn off this binder. I would suggest that you do it on a nice day when you are staying home and can open the windows as it will smell quite horrid for a while.
Apr 09, 2009 | GE JBP24 QuickClean Electric Kitchen Range
Oven ignites by itself
Any chance that the plastic knob was cracked and not really turning the shaft of the thermostat?
What did you find the problem. I know this response is 2 months after the last post above.
Eddie
Jun 08, 2008 | Hotpoint RGB745 Gas Kitchen Range
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
128 people viewed this question
Top Maytag Kitchen Ranges Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
