Paper tray ran out of paper and had a paper jam. removed the jam and got an error L100-00. How do I fix this. Have lots of work to do today?
Hi:
If the error code is an L-1 the most lokely cause is the scanner lock on your machine is engaging with the scanner assy. Bend down and look at the left front corner of the copier right inside of the area where you grab your copies. You should see a clear round plastis knob. This has to be in the fully unlocked position If it is partly turned then this can be stalling your scanner assy and throwing the error code your seeing.
Good Luck
Andrew
One thing I always do if I have a client who is constantly accidentally latching that scanner lock is remove the scan glass and it's pretty easy to bust out of the bottom of the scanner deck with a screw driver.
